Inverter RS Smart Solar - PIN482601000 | |
INVERTER | |
DC Input voltage range (1) | 38 – 62V |
AC Output (2) | Output voltage: 230 Vac ± 2% Frequency: 50 Hz ± 0,1% (1) Maximum continuous inverter current : 25 Aac |
Continuous output power at 25°C | Increases linearly from 4800 W at 46 VDC to 5300 W at 52 VDC |
Continuous output power at 40°C | 4500W |
Continuous output power at 65°C | 3000W |
Peak power (3) | 9 kW for 3 seconds 7 kW for 4 minutes |
Short-circuit output current | 45 A |
Max. AC output overcurrent protection | 30 A |
Maximum efficiency | 96.5% at 1 kW load 94% at 5 kW load |
Zero load power | 20W |
Low battery shutdown | 37.2 V (adjustable) |
Low battery restart | 43.6 V (adjustable) |
SOLAR | |
Maximum DC voltage (4) | 450 V |
Start-up voltage | 120 V |
MPPT voltage range | 65 – 450 V |
Maximum operational PV input current limit | 18 A |
Max. PV short circuit current | 20 A |
Maximum DC solar charging power | 4000 W |
Earth leakage trip level | 30 mA |
Isolation fail level (detection before start-up) | 100 kΩ |
CHARGER | |
Programmable charger voltage range (5) | 36 - 60 V |
Charge voltage 'absorption' | default: 57.6 V (adjustable) |
Charge voltage 'float' | default: 55.2 V (adjustable) |
Maximum charge current from AC (6) | 88 A @ 57.6V |
Total maximum combined charger current (AC + PV) | 100 A |
Battery temperature sensor | Included |
Battery voltage sense | Yes |
GENERAL | |
Parallel and 3-phase operation | 12 parallel units supported, 3 phase supports 4 units per phase |
Programmable relay (8) | Yes |
Protection (9) | a - g |
Data Communications (10) | VE.Direct port, VE.Can port & Bluetooth |
Bluetooth frequency | 2402 - 2480 MHz |
Bluetooth power | 4 dBm |
General purpose analog/digital in port | Yes, 2x |
Remote on-off | Yes |
Operating temperature range | -40 to +65°C (fan assisted cooling) |
Maximum altitude | 2000 m |
Humidity (non-condensing) | max 95% |
ENCLOSURE | |
Material & Color | steel, blue RAL 5012 |
Protection category | IP21 Protective Class: I |
Battery-connection | M8 Bolts |
PV Connection | 2 positive & 2 negative MC4 |
230 V AC-connection | Screw terminals 10 mm² (6 AWG) |
Weight | 11 kg |
Dimensions (hxwxd) | 425 x 440 x 125 mm |
STANDARDS | |
Safety | EN-IEC 60335-1, EN-IEC 60335-2-29, EN-IEC 62109-1, EN-IEC 62109-2 |
Emission, Immunity | EN 55014-1, EN 55014-2 EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 Pollution Degree 2 |
Overvoltage Category | Battery: OVC I PV port: OVC II AC in / AC out: OVC III |
1) Minimum start-up voltage is 41 VDC. Over-voltage disconnect: 65,5 V. 2) Can be adjusted to 240VAC and 60 Hz 3) Peak power capacity and duration depends on start temperature of heatsink. Mentioned times are with cold unit. 4) The maximum PV voltage should not exceed 8x battery float voltage. If for example the float voltage of the battery is 50 V, the maximum PV voltage should not exceed 8 x 50 = 400 V. 5) The Charger set points (float & absorption) can be set to max 60 V. The output voltage at the charger terminals can be higher due to compensation for temperature & voltage drop over the battery cables. The maximum output current is reduced on a linear basis from full current at 60 V to 5A at 62 V. The equalization voltage can be set to max 62V, the equalization current percentage can be set to max 6%. 6) The maximum charge current from AC sources depends on input voltage and battery current. At 230V input and 57.6V battery voltage, and 25C ambient, the maximum charge current is 88A. See manual, limitations section, for further details. 8) Programmable relay which can be set for general alarm, DC under voltage or genset start/stop function. DC rating: 4 A up to 35 VDC and 1 A up to 70 VDC 9) Protection key: a) output short circuit b) overload c) battery voltage too high d) battery voltage too low e) temperature too high f) 230 VAC on inverter output g) solar earth leakage. 10) Not currently compatible with VE.Smart Networks. Connection to a GX device (i.e. Cerbo GX) must be made via the VE.Can interface. The VE.Direct interface is for connection to the GlobalLink 520. |
