Battery specification | |||||||||
VOLTAGE AND CAPACITY | |||||||||
Battery model LFP-Smart | 12,8/ 50 | 12,8/ 100 | 12,8/ 160 | 12,8/ 180 | 12,8/ 200 | 12,8/ 330 | 25,6/ 100 | 25,6/ 200-a | |
Nominal voltage | 12.8V | 12.8V | 12.8V | 12.8V | 12.8V | 12.8V | 25.6V | 25.6V | |
Nominal capacity @ 25°C* | 50Ah | 100Ah | 160Ah | 180Ah | 200Ah | 330Ah | 100Ah | 200Ah | |
Nominal capacity @ 0°C* | 40Ah | 80Ah | 130Ah | 150Ah | 160Ah | 260Ah | 80Ah | 160Ah | |
Nominal capacity @ -20°C* | 25Ah | 50Ah | 80Ah | 90Ah | 100Ah | 160Ah | 50Ah | 100Ah | |
Nominal energy @ 25°C* | 640Wh | 1280Wh | 2048Wh | 2304Wh | 2560Wh | 4220Wh | 2560Wh | 5210Wh | |
Capacity loss | (per 100 cycles, @ 25 °C, 100 % DoD): <1 % | ||||||||
Energy loss | (per 100 cycles, @ 25 °C, 100 % DoD): <1 % | ||||||||
Round trip efficiency | 92 % |
CYCLE LIFE (capacity ≥ 80% of nominal) | |
80% DoD | 2500 cycles |
70% DoD | 3000 cycles |
50% DoD | 5000 cycles |
DISCHARGE | ||||||||||
Maximum continuous discharge current | 100A | 200A | 320A | 360A | 400A | 400A | 200A | 400A | ||
Recommended continuous discharge current | ≤50A | ≤100A | ≤160A | ≤180A | ≤200A | ≤300A | ≤100A | ≤200A | ||
End of discharge voltage | 11.2V | 11.2V | 11.2V | 11.2V | 11.2V | 11.2V | 22.4V | 22.4V |
OPERATING CONDITIONS | |
Operating temperature | Discharge: -20°C to +50°C Charge: +5°C to +50°C |
Storage temperature | -45°C to +70°C |
Humidity (non-condensing) | Max. 95% |
Protection class | IP 22 |
CHARGE | ||||||||||
Charge voltage | Between 14V/28V and 14.4V/28.8V (14.2V/28.4V recommended) | |||||||||
Float voltage | 13.5V/27V | |||||||||
Maximum charge current | 100A | 200A | 320A | 360A | 400A | 400A | 200A | 400A | ||
Recommended charge current | ≤30A | ≤50A | ≤80A | ≤90A | ≤100A | ≤150A | ≤50A | ≤100A |
MOUNTING | ||||||||||
Can be placed on their sides | Yes 2) | Yes 2) | Yes 2) | Yes 2) | Yes 2) | No 1) | Yes2) | Yes 2) |
OTHER | ||||||||||
Max storage time @ 25°C 1) | 1 year | |||||||||
BMS connection | Male + female cable with M8 circular 3 pole connector, length 50cm | |||||||||
Power connection (threaded inserts) | M8 | M8 | M8 | M8 | M8 | M10 | M8 | M8 | ||
Dimensions (h x w x d) mm | 199 x 188 x147 | 197 x 321 x 152 | 237 x 321 x 152 | 237 x 321 x 152 | 237 x 321 x 152 | 265 x 359 x 206 | 197 x 650 x 163 | 237 x 650 x 163 | ||
Weight | 7kg | 14kg | 18kg | 18kg | 20kg | 29kg | 28kg | 39kg |
STANDARDS | ||||||||||
Safety | Battery model LFP-Smart 12.8/50 & 12.8/100: Cells: UL1973 + IEC62619:2017 + UL9540A Battery model LFP-Smart 12.8/160: Cells: IEC 62133:2012 Battery model LFP-Smart 12.8/200: Cells: UL1973 + IEC62619:2017 + UL9540A Battery: IEC62619:2017 + IEC62620:2014 Battery model LFP-Smart 12.8/330: Cells: UL1642 Battery model LFP-Smart 25.6/100: Cells: UL1973 + UL9540A Battery model LFP-Smart 25,6/200-a: Cells: UL1973 + IEC62619:2017 + UL9540A Battery: IEC62620:2014 | |||||||||
EN 60335-1:2012/AC:2014, EN-IEC 62368-1: 2020, IEC 61427-1:2013 | ||||||||||
EMC | EN-IEC 61000-6-3:2007/A1:2011/AC:2012 - EN 55014-1:2017/A11:2020 | |||||||||
Automotive | ECE R10-6 | |||||||||
* Discharge current ≤1C 1) When fully charged 2) The lithium battery can be mounted upright and on its side, but not with the battery terminals facing down 3) ) The 12,8V/330Ah lithium battery may only be mounted in an upright position |
