10. Technical specifications Lynx Distributor
Power | |
Voltage range | 9 - 60Vdc |
Supported system voltages | 12, 24 or 48V |
Reverse polarity protection | Yes (1) |
Current rating | 1000Adc continuous |
Power consumption (2) | Maximum 100mA (with all LEDs illuminated) |
(1) The RJ10 cable connection is not protected against reverse polarity (2) Powered from Lynx Shunt VE.Can or Lynx Smart BMS |
Connections | |
Busbar | M8 or M10 |
Fuses | M8 |
Power(3) and data(4) | 40 cm RJ10 cable (included) |
(3) Powered from Lynx Shunt VE.Can or Lynx Smart BMS (4) Data can only be received by a Lynx Smart BMS |
Physical | |
Enclosure material | ABS |
Enclosure dimensions (hxlxw) | 290 x 170 x 80 mm |
Unit weight | 2.2 kg |
Busbar material | Tinned copper |
Busbar material (hxw) | 8 x 30mm |
Environmental | |
Operating temperature range | -40°C to +60° |
Storage temperature range | -40°C to +60° |
Humidity | Max. 95% (non-condensing) |
Protection class | IP22 |
