The internal physical parts and the wiring diagram of the Lynx Distributor indicating the following parts:
Positive busbar
Negative busbar
Fuses
Positive connections
Negative connections
Ground connection
The Internal physical parts of the Lynx Distributor
The internal wiring diagram of the Lynx Distributor
The Lynx Distributor monitors each fuse and will detect a blown fuse.
When a fuse blows, the red fuse LED will illuminate, the power LED will turn red, and an alarm message is sent to a connected Lynx Smart BMS.
Fuse detection is possible from all fuses on the battery side or the load or charger side. Be aware that the fuse detection has a particularity; when batteries are connected to multiple Lynx Distributor circuits and if one of the battery fuses blows, the fuse monitor will not measure a high enough voltage over the fuse to trigger a broken fuse alarm until the battery is being charged or discharged.
Note
The fuse monitors in Lynx Distributor modules with older firmware (before serial number HQ1909) cannot detect a blown fuse when batteries are connected. It can only detect a blown fuse if loads are connected.
The RJ10 cable supplies power to the Lynx Distributor from a Lynx Smart BMS or Lynx Shunt VE.Can and transfers data between the Lynx Distributor and the Lynx Smart BMS.
The Lynx Distributor does not have an in-built power supply to supply its fuse detection circuit; it relies on this power to be supplied from a Lynx Shunt VE.Can or a Lynx Smart BMS via the RJ10 cable. If the Lynx Distributor is used without a Lynx Shunt VE.Can or a Lynx Smart BMS, it needs to be powered in an alternative way so that the fuse detection circuit is operational.
To power the RJ10 cable for standalone use, do the following:
Connect pin 1 of the RJ10 connector to 5V (4.5V-5.5V).
Connect pin 4 to GND.
Warning
The RJ10 connection is not protected against reverse polarity. A wrong RJ10 connection can irreversibly damage the Lynx Distributor’s electronic circuits.
The Lynx Distributor communicates the operational status and the status of each fuse via the RJ10 cable to a Lynx Smart BMS. The data can then be accessed via the VictronConnect App, GX device and the VRM portal.
Note
The communication feature has been implemented in the Lynx Distributor from serial number HQ1909 or above.
Notice
Communication is not possible in combination with the Lynx Shunt VE.Can.
