Solar & Wind Priority
4. Operation
Once solar and wind priority is activated, it can be overridden at any time via a virtual switch in VictronConnect, the VRM portal or the GX device to force charging with shore power to charge the battery to 100%. Once charging is complete, the system will return to sustain mode and prioritise solar and wind power.
This is especially useful when you go on a trip with a fully charged battery or to balance the lithium batteries. The forced charging via shore power can be cancelled anytime using the same switch.
Via VictronConnect:
To force a charge from shore power or stop a forced charge with VictronConnect:
  1. Open VictronConnect and tap on the VE.Bus inverter/charger overview (connected either via VE.Bus Smart Dongle or MK3 to USB interface)
  2. Tap the Solar & Wind icon next to the battery icon.
  3. Tap 'OK' in the pop-up window.
VC_Forced_Charge_1.svg
VC_Forced_Charge_2.svg
Via GX device menu:
To force a charge from shore power or stop a forced charge via the Remote Console:
  1. Open the Remote Console.
  2. Go to Device List → [your_MultiPlus_or Quattro].
  3. Click on 'Charge the battery to 100%'.
  4. In the menu that opens, click 'Yes'.
  5. Click 'Charging the battery to 100%' to stop the forced charge.
  6. In the menu that opens, click 'Yes'.
GX_Forced_Charging_Start_1.svg
GX_Forced_Charging_Start_2.svg
GX_Forced_Charging_Stop.svg
Via VRM Portal:
To force a charge from shore power or stop a forced charge via the VRM Portal:
  1. Access the VRM portal (using the VRM app or a browser) and select the installation where you want to charge the battery to 100%.
  2. Navigate to the installation dashboard and click the ‘Controls’ button Bildschirmfoto_2024-09-13_um_10_17_16.png in the top-right corner.
  3. Click on 'Charge battery to 100%'.
  4. In the next window, either confirm the action or wait for the 5-second timer to expire. The battery will then charge to 100% from shore power.
  5. To stop the charging process at any time before it’s finished, click the ‘Controls’ button again and select ‘Stop charging battery to 100%'.
Watch the video below to learn how to use the solar and wind priority features:
