Battery monitor | BMV-702 | ||
Supply voltage range | 6.5 - 95 Vdc | ||
Current draw (backlight off) | < 4mA | ||
Input voltage range, auxiliary battery | 6.5 - 95Vdc | ||
Battery capacity (Ah) | 1 - 9999Ah | ||
Operating temperature range | -40 +50°C (-40 - 120°F) | ||
Temperature measurement range* | -20 +50°C (-4 - 120°F) | ||
VE.Direct communication port | Yes | ||
Relay | 60V / 1A normally open (function can be inverted) | ||
RESOLUTION & ACCURACY (with a 500A shunt) | |||
Current | ± 0.01A | ||
Voltage | ± 0.01V | ||
Amp hours | ± 0.1Ah | ||
State of charge (0 - 100%) | ± 0.1% | ||
Time-to-go | ± 1 min | ||
Temperature (0 - 50°C or 30 - 120°F) * | ± 1°C/°F | ||
Accuracy of current measurement | ± 0.4% | ||
Accuracy of voltage measurement | ± 0.3% | ||
INSTALLATION & DIMENSIONS | |||
Installation | Flush mount | ||
Head unit front diameter | 63mm (2.5 inch) | ||
Head unit front bezel | 69 x 69mm (2.7 x 2.7 inch) | ||
Head unit body diameter and depth | 52mm (2.0 inch) and 31mm (1.2 inch) | ||
Shunt connection bolts | M10 (0.3937 inch) | ||
Head unit protection category | IP55 (not intended for outdoor use) | ||
STANDARDS | |||
Safety | EN 60335-1 | ||
Emission / Immunity | EN 55014-1 / EN 55014-2 | ||
Automotive | ECE R10-4 / EN 50498 | ||
ACCESSORIES | |||
Shunt (included) | 500A / 50mV | ||
Cables (included) | 10 meter 6 core UTP with RJ12 connectors. 2 cables with 1A slow blow fuse for the battery positive connection. | ||
Temperature sensor | Optional (ASS000100000) |
* Only when the optional temperature sensor is connected, the Temperature sensor for BMV-712 Smart and BMV-702. This temperature sensor is not included.
