Lithium NG 12,8V battery manual
8. Technical data
8.1. Battery specification
VOLTAGE AND CAPACITY
Battery model
LFP 12,8 V/100 Ah
LFP 12,8 V/150 Ah
LFP 12,8 V/200 Ah
LFP 12,8 V/300 Ah
Nominal voltage
12,8 V
Nominal capacity @ 25 °C*
100 Ah
150 Ah
200 Ah
300 Ah
Nominal energy @ 25 °C*
1280 Wh
1920 Wh
2560 Wh
3840 Wh
Capacity loss
(per 100 cycles, @ 25 °C, 100 % DoD): <1 %
Energy loss
Round trip efficiency
92 %
* Discharge current ≤ 1C
CYCLE LIFE (capacity ≥ 80% of nominal)
80 % DoD
2500 cycles
70 % DoD
3000 cycles
50 % DoD
5000 cycles
DISCHARGE
Max continuous discharge current (C-rate)
100 A (1C)
150 A (1C)
200 A (1C)
300 A (1C)
Max pulse discharge current 10s (C-rate)
200 A (2C)
300 A (2C)
400 A (2C)
600 A (2C)
End of discharge voltage
11,2 V
Internal resistance
2 mΩ
1 mΩ
CHARGE
Charge voltage
Between 14 V and 14,2 V
Float voltage
13,5 V
Max continuous charge current (C-rate)
100 A (1C)
150 A (1C)
200 A (1C)
300 A (1C)
Max pulse charge current 10s (C-rate)
200 A (2C)
225 A (1.5C)
400 A (2C)
450 A (1.5C)
GENERAL
BMS-es
Lynx Smart BMS NG 500 A / 1000 A (M10 busbars), must be purchased separately
Cell measurements
Cell voltages and temperatures, battery current
Battery BMS interface
Male + female cable with M8 circular connector with high-speed digital communication, length 50 cm
M8 extension cables are available separately for purchase in various lengths between 1 and 5 meters
Alarm feature
Pre-alarm contact on BMS
Bluetooth
In the BMS
Max batteries per BMS
50 (384 kWh per BMS 3))
Battery firmware updates
Battery firmware automatically updated by BMS
Repairable
Yes (cover can be removed with screws)
OPERATING CONDITIONS
Operating temperature
Discharge: -20 °C to +50 °C | Charge: +5 °C to +50 °C
Storage temperature
-45 °C to +70 °C
Humidity (non-condensing)
Max. 95 %
Protection class
IP65
MOUNTING
Mounting options
Strap or mounting brackets (brackets included)
Can be placed on their sides
Yes 2)
OTHER
Self-discharge rate
≤ 3 % per month @ 25 °C
Power connection
M8 (threaded inserts and bolts)
Dimensions (h x w x d) (mm)
235 x 197 x 160
205 x 250 x 205
235 x 341 x 160
206 x 447 x 205
Weight (est.)
9 kg
14 kg
19 kg
29 kg
STANDARDS
Safety
Cells: UL1973 UL9540A IEC62619
Cells: UL1973 UL9540A IEC62619 (all three pending)
Battery:  IEC62619 (pending)
EMC
EN 61000-6-3, EN 61000-6-2
Automotive
ECE R10-6 (pending)
Performance
IEC 62620 (pending)
1) When fully charged
2) The lithium battery can be mounted upright and on its side, but not with the battery terminals facing down
3) Up to 5 BMS-es can be paralleled. This requires a firmware update, expected in Q3 2024.
8.2. Enclosure dimensions
LiFePO4_Battery_12_8V100Ah_NG__BAT512110620_.pdf
LiFePO4_Battery_12_8V_150Ah_NG.pdf
LiFePO4_Battery_12_8V200Ah_25_6V100Ah_NG__BAT512120620_BAT524110620_.pdf
LiFePO4_Battery_12_8V_300Ah_NG.pdf
