Lithium NG 12,8V battery manual
7. Warnings, alarms and errors
7.1. E-SL1: Balancer failure
Tip
Contact your dealer or distributor to resolve this situation.
7.2. W-SL11: Under voltage warning (pre-alarm)
  • The voltage of one or more cells is becoming too low and has dropped below the pre-alarm setting.
    Tip
    To remedy this warning, recharge the battery as soon as possible.
7.3. A-SL9 Over voltage alarm
  • The voltage of one or more cells has become too high.
    Tip
    Immediately disable all chargers and contact the system installer to check that all chargers are properly controlled by the “charge disconnect” contact on the BMS. When properly controlled, a high voltage situation is not possible, as the BMS disconnects all chargers well before raising the high voltage alarm.
7.4. A-SL11: Under voltage alarm
  • The voltage of one or more cells is below the configured Allow-To-Discharge cell voltage and discharging has been disabled
    Tip
7.5. A-SL15: Over temperature alarm
  • The battery has reached its high-temperature threshold and charging is disabled.
    Tip
    Provide adequate ventilation and make sure there is enough space around the battery. Reduce charging current and/or loads.
7.6. A-SL22: Under temperature alarm
  • The battery has reached its low-temperature threshold and charging is disabled.
    Tip
    As soon as the temperature rises above the set threshold, the charging process will continue.
7.7. E-SL2: Internal communitation failure
Tip
7.8. E-SL9: Overlapped voltage error
Tip
7.9. E-SL10: Balancer update error
Tip
7.10. E-SL24: Hardware failure
This error is generated in the following circumstances:
  1. One (or more) cells are very deeply discharged or defective.
    Tip
    Check the battery terminal voltage. If the battery terminal voltage is too low, refer to the Battery very low terminal voltage chapter on what to do next.Battery very low terminal voltage
  2. The internal circuit board has a hardware fault.
    Tip
    To resolve this, contact your Victron Energy dealer or distributor.
Note
To resolve a "hardware failure" error, always first refer to the Troubleshooting & support chapter of this manual before contacting your Victron Energy dealer or distributor. This is to rule out the first two possible causes of this error. Do not just assume that a hardware failure causes the error.Troubleshooting & support
7.11. E-SL119: Settings data lost
  • The settings data in the battery memory has been lost.
    Tip
    To remedy this, go to the settings page and reset settings to factory defaults.
    If this error is not resolved after a settings reset, contact your Victron Energy dealer or distributor and ask for this issue to be escalated to Victron Energy, as this error should never happen. Please include the battery's serial number and firmware version.
