MPPT 150/35 | MPPT 150/45 | |
Battery voltage | 12V / 24V / 48V Auto select, 36V: Manual select | |
Maximum battery current | 35A | 45A |
Nominal PV power, 12V 1a,b | 500W | 650W |
Nominal PV power, 24V 1a,b | 1000W | 1300W |
Nominal PV power, 36V 1a,b | 1500W | 1950W |
Nominal PV power, 48V 1a,b | 2000W | 2600W |
Max. PV short circuit current 2 | 35A | 45A |
Maximum PV open circuit voltage | 150V | |
Peak efficiency | 98% | |
Self-consumption | 12V: 20mA / 24V: 15mA / 48V: 10mA | |
Charge voltage 'absorption' | Default setting: 14.4V / 28.V / 43.2V 57.6V (adjustable) | |
Charge voltage 'float' | Default setting: 13,8V / 27,6V 14.4V / 55,2V (adjustable) | |
Charge voltage ‘equalization’ 3) | Default setting: 16.2V / 32.4V / 48.6V / 64.8V (adjustable) | |
Charge algorithm | Multi-stage adaptive (eight pre-programmed algorithms) or user defined algorithm | |
Temperature compensation | -16mV/°C / -32mV/°C / -64mV/°C | |
Protection | PV reverse polarity, output short circuit, over-temperature | |
Operating temperature | -30°C to +60°C (full rated output up to 40°C) | |
Humidity | 95%, non-condensing | |
Maximum altitude | 5000m (full rated output up to 2000m) | |
Environmental condition | Indoor type 1, unconditioned | |
Pollution degree | PD2 | |
Data communication | VE.Direct 4 Bluetooth, via the VictronConnect app | |
ENCLOSURE | ||
Colour | Blue (RAL 5012) | |
Power terminals | 16mm² / AWG6 | |
Protection category | IP43 (electronic components), IP22 (connection area) | |
Weight | 1.25kg | |
Dimensions h x w x d | 130 x 186 x 70 mm | |
STANDARDS | ||
Safety | EN/IEC 62109-1/ UL 1741 / CSA C22.2 NO.107.1-16 | |
1a) The solar charger will limit input power if more PV power is connected. 1b) The PV voltage must exceed Vbat + 5V for the controller to start. Thereafter the minimum PV voltage is Vbat + 1V. 2) A higher short circuit current may damage the solar charger in case of reverse polarity connection of the PV array. 3) Equalization is by default disabled. 4) For more information on data communication see the data communication paper in the Technical information section on our website. |
