MultiPlus-II GX | 24/3000/70-32 | 48/3000/35-32 | 48/5000/70-50 | ||||
PowerControl & PowerAssist | Yes | ||||||
Transfer switch | 32A | 32A | 50A | ||||
Maximum AC input current | 32A | 32A | 50A | ||||
Auxiliary output | Yes (32A) | ||||||
INVERTER | |||||||
Input voltage range | 19 - 33 V | 38 – 66V | |||||
Output in inverter mode (1) | Output voltage: 230 VAC ± 2% Frequency: 50 Hz ± 0,1% | ||||||
Cont. output power at 25°C (3) | 3000VA | 3000VA | 5000VA | ||||
Cont. output power at 25°C | 2400W | 2400W | 4000W | ||||
Cont. output power at 40 | 2200W | 2200W | 3700W | ||||
Cont. output power at 65°C | 1700W | 1700W | 3000W | ||||
Maximum feed-in power | 3000VA | 3000VA | 5000VA | ||||
Peak power | 5500W | 5500W | 9000W | ||||
Maximum efficiency | 94% | 95% | 96% | ||||
Zero load power | 13W | 11W | 18W | ||||
Zero load power in AES mode | 9W | 7W | 12W | ||||
Zero load power in Search mode | 3W | 2W | 2W | ||||
CHARGER | |||||||
AC Input | Input voltage range: 187-265 VAC Input frequency: 45 – 65 Hz | ||||||
Charge voltage 'absorption' | 28.8V | 28.8V | 57.6V | ||||
Charge voltage 'float' | 27.6V | 28.8V | 55.2V | ||||
Storage mode | 26.4V | 52.8 V | 52.8V | ||||
Maximum battery charge current (4) | 70A | 35A | 70A | ||||
Battery temperature sensor | Yes | ||||||
GENERAL | |||||||
Programmable (AUX) relay (5) | Yes | ||||||
Auxiliary power supply | 12V / 100mA | ||||||
Programmable open collector output | 70V / 100mA | ||||||
Analog-digital aux inputs | Yes, 2x | ||||||
Temperature sensor | Yes | ||||||
Voltage sense contacts | Yes | ||||||
Protection (2) | a - g | ||||||
VE.Bus communication port | For parallel and three-phase operation, remote monitoring and system integration | ||||||
General purpose communication port | Yes, 2x | ||||||
Interfaces | VE.Can, USB, Ethernet, VE.Direct, Wi-Fi | ||||||
External AC current sensor (optional) | 50A | 50A | 100A | ||||
Remote on-off | Yes | ||||||
Operating temperature range | -40 to +65 °C (fan-assisted cooling). Maximum Altitude 2000m | ||||||
Humidity (non-condensing) | max 95% | ||||||
ENCLOSURE | |||||||
Material and colour | Steel, blue RAL 5012 | ||||||
Protection category | IP22 | ||||||
Battery connection | M8 bolts | ||||||
230VAC connection | Screw terminals 13 mm2 (6 AWG) | ||||||
Weight | 20kg | 20Kg | 31kg | ||||
Dimensions hxwxd (mm) | 506 x 275 x 147 mm | 506 x 275 x 147 mm | 565 x 323 x 148 mm | ||||
STANDARDS | |||||||
Safety | EN-IEC 62019-1, EN-IEC 6201-2, EN-IEC 60335-1, EN-IEC 60335-2-29 | ||||||
Emission / Immunity | EN55014-1, EN 55014-2 EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 | ||||||
Uninterruptible power supply | IEC 62040-1 | ||||||
SIMPLIFIED EU DECLARATION OF CONFORMITY: Hereby, Victron Energy B.V. declares that the is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: .
UK PSTI STATEMENT OF COMPLIANCE: We, Victron Energy B.V., confirm that our product complies with the security requirements outlined in Schedule 1 of The Product Security and Telecommunications Infrastructure (Security Requirements for Relevant Connectable Products) Regulations 2023. The official Statement of Compliance can be downloaded from
