Specification | 12/30 (1+1) & (3) | 12/50 (1+1) & (3) | 24/16 (1+1) & (3) | 24/25 (1+1) & (3) |
Nominal input voltage - AC supply | 120 – 240VAC | |||
Input voltage range – AC supply | 85 – 250VAC (full power from 100VAC, startup from 90VAC) | |||
Input frequency - AC supply | 45 - 65Hz | |||
Input voltage - DC supply | 90 - 375 VDC | |||
Power factor | >0.99 | |||
Max Efficiency - 230VAC / 120VAC | 95% / 93% | 94% / 92% | 96% / 94% | 96% /94% |
Charge voltage - Absorption / Float / Storage | Normal: 14.4V / 13.8V / 13.2V High: 14.7V / 13.8V / 13.2V Li-ion: 14.2V / N/A / 13.5V | Normal: 28.8V / 27.6V / 26.4V High: 29.4V / 27.6V / 26.4V Li-ion: 28.4V / N/A / 27.0V | ||
Temperature compensation (N/A for Li-ion) | -16mV/°C | -32mV/°C | ||
Charge algorithm | 6-stage adaptive (3 stage for Li-ion) | |||
Max output current - Normal mode | 30A | 50A | 16A | 25A |
Max output current - Low current mode | 15A | 25A | 8A | 12.5A |
Max output current - Starter battery | 4A (1+1 output models only) | |||
Back drain current | <1mA | |||
Max battery capacity (recommended) | 300Ah | 500Ah | 160Ah | 250Ah |
Min battery capacity - Normal mode | Lead: 120Ah Li-ion: 60Ah | Lead: 200Ah Li-ion: 100Ah | Lead: 64Ah Li-ion: 32Ah | Lead: 100Ah Li-ion: 50Ah |
Min battery capacity - Low current mode | Lead: 60Ah Li-ion: 30Ah | Lead: 100Ah Li-ion: 50Ah | Lead: 32Ah Li-ion: 16Ah | Lead: 50Ah Li-ion: 25Ah |
Data communication | VE.Direct and Bluetooth (via VictronConnect app) | |||
Bluetooth power and frequency | -4dBm | 2402 - 2480MHz | |||
Remote on/off | Yes (2 pole terminal) | |||
Programmable relay | Yes (SPDT - 5A up to 250VAC / 5A up to 28VDC) | |||
Operating temperature | -20 to +60°C (0 - 140°F) Full rated output up to 40°C | |||
Max humidity | 95% | |||
Enclosure | ||||
Material and colour | Aluminium | Blue RAL 5012 | |||
AC connection | IEC 320 C14 inlet with retainer clip (AC cord ordered separately) | |||
Battery connection | Screw terminals 16 mm² (AWG6) | |||
Number of battery connections | (1+1) models: 2 (2nd output via 2 pole terminal) | (3) models: 3 | |||
Protection category | Electronic components: IP43 | Connection area: IP22 | |||
Weight | 2.7 kg (6.0 lbs) | |||
Dimensions (h x w x d) | 180 x 249 x 116mm (7.1 x 9.8 x 4.6 inch) | |||
Compliance standards | ||||
Safety | EN 60335-1, EN 60335-2-29 | |||
Emission | EN 55014-1, EN 61000-6-3, EN 61000-3-2 | |||
Immunity | EN 55014-2, EN 61000-6-1, EN 61000-6-2, EN 61000-3-3 | |||
Vibration | IEC68-2-6:10-150Hz/1.0G |
