For unexpected behaviour or suspected product faults, refer to this chapter.
Start by checking the common issues described here. If the problem persists, contact the point of purchase (Victron dealer or distributor) for technical support.
If you're unsure who to contact or if the point of purchase is unknown, refer to the Victron Energy Support webpage.
The display does not power up. The screen is blank and the back-light is off.
The display is powered from the solar charger. The solar charger is powered from either the battery or the PV array. If the PV voltage and the battery voltage are both below 6V, the display will not power up.
It could also be that the LCD display is not properly inserted into the socket on the solar charger.
The screen is blank or faint, but the back-light is still operational.
This may be due to low ambient temperature. If the ambient temperature is below -10°C (14°F), the LCD segments can become faint. Below -20°C (-4°F) the LCD-segments can become invisible.
During charging the LCD-display will warm up, and the LCD segments will become visible again.
The display is in "auto scroll mode". In this mode the display will continuously cycle through each live data menu item every 5 seconds.
To stop the auto scroll mode, briefly press the "-" or the "+" button.
If the setup menu is locked settings can only be viewed but not changed.
To unlock the settings menu see the instruction in the Setup menu chapter.
