The LCD screen displays the following information:
A number reading.
The unit of the reading: V, A, W, kWh, h or °C/°F.
The type of reading: battery, PV or temperature.
State: charge and charge stage indication.
Connection indicator and warning indicator.
Full LCD readout
The digits used to represent letters and numbers
The buttons on the front of the display are used to navigate through the solar charger readings and are used when making solar controller and display settings.They have the following functions:
Button | Action |
Cancel or Back | |
Select or Conform | |
Go to next or previous item or Increase or decrease value |
This menu shows the live solar charger readings. The SmartSolar Control display always starts up in this menu.
Press the - and + button to cycle through all menu items.
Press the - button to see the live data of the solar charger. Each time the - button is pressed, the next parameter will be displayed.
If the + and - button is pressed at the same time for 4 seconds, the auto scroll mode will be activated. The display will continuously cycle through each menu item every 5 seconds. To stop the auto scroll mode, briefly press the "-" or the "+" button.
These menu items will be displayed in order of appearance as indicated in below table:
LCD display | Menu item | Description and notes |
Battery voltage and charge current when no PV is present Battery voltage and charge current when PV is present | The first number indicates the battery voltage (V), the second number indicates the battery charge current (A). | |
Battery charge current | Charge stage: Bulk, Absorption, Float or off. | |
Battery voltage | Charge stage: Bulk, Absorption, Float or off. | |
Battery charge power | Charge stage: Bulk, Absorption, Float or off. | |
Battery temperature | The temperature is shown or A special message is shown:
Solar charger temperature | The temperature is shown or A special message is shown:
PV current | Solar array output current | |
PV voltage | Solar array output voltage | |
PV power | Solar array output power |
In addition to above menu items, the following menu items will appear when special conditions occur:
Warning message | "Inf" together with a number is displayed. This number refers to an error code, see solar charger manual for the meaning of this code. | |
Error message | "Err" together with a number is displayed. This number refers to an error code, see solar charger manual for the meaning of this code. | |
Remote operation | "remote" is displayed. | |
BMS operation | "bms" is displayed. |
The charge stage and if PV is active is indicated by the bottom line of the display:
LCD display | Description | Notes |
Bulk charge stage | The first charge stage, the battery is between 0 and 80% state of charge. | |
Absorption charge stage | The middle charge stage, the battery is between 80% and 100% state of charge. | |
Float charge stage | The last charge stage, the battery 100% state of charge. |
The history menu shows both the daily and overall solar charger history data. It shows items such as solar yield, battery voltages, time spend in each charge stage and past errors.
To enter and read out the historical menu:
Press the SELECT button, while in the status menu.
A scrolling text will be visible.
Press the + or – button to navigate through the history items.
When arriving at the desired history item, press the SELECT button to see the value of that item.
If an item contains multiple values, Press + or – button to browse the various values within that item.
For the daily items it is possible to scroll back to 30 days ago (data becomes available over time), a brief popup shows the day number.
To go back to the main history menu, press the SETUP button.
To go back to the status menu, press the SETUP button again.
All available history menu items are listed in below table, in the order they appear when scrolling through the items.
Scrolling text | LCD | Description |
* When the charger is not active (night time) the bulk, absorption and float icons will be shown as in the table above. When the charger is active only one icon will be shown: the icon corresponding to the actual charge state. | ||
YIELD TOTAL | The cumulative PV yield since the last history reset. | |
LAST ERROR | The last 4 errors since the last history reset. Only available if there actually were any error(s):
PANEL VOLTAGE MAXIMUM | The maximum PV voltage since the last history reset. | |
BATTERY VOLTAGE MAXIMUM | The maximum battery voltage since the last history reset. | |
YIELD | The daily PV yield, available for each day for the past 30 days. | |
BATTERY VOLTAGE MAXIMUM | The daily maximum battery voltage, available for each day for the past 30 days. | |
BATTERY VOLTAGE MINIMUM | The daily minimum battery voltage, available for each day for the past 30 days. | |
LAST ERROR | The last 4 daily errors. Only available if there actually were any error(s):
TIME BULK | Daily time spent in bulk charge stage or in ESS, in minutes, available for each day for the past 30 days. * | |
TIME ABSORPTION | Daily time spent in absorption charger stage, in minutes, available for each day for the past 30 days. * | |
TIME FLOAT | Daily time spent in float charge stage, in minutes, available for each day for the past 30 days. * | |
MAXIMUM POWER | The daily maximum PV power, available for each day for the past 30 days. | |
BATTERY CURRENT MAXIMUM | The daily maximum battery current, available for each day for the past 30 days. | |
PANEL VOLTAGE MAXIMUM | The daily maximum PV current, available for each day for the past 30 days. |
In the settings menu the solar charger and SmartSolar Control settings can be viewed and/or changed.
Caution
Do not change settings unless you know what they are and what the effect of changing these setting can be. Incorrect settings may cause system problems including damage to batteries. When in doubt, seek advice from and experienced Victron Energy installer, dealer or distributor.
To navigate the settings menu:
Press the SETUP button for 3 seconds to enter the setup menu.
The display will show the text “Menu” and the first menu item is shown via a scrolling text.
Navigate to the desired setting by pressing the - or + button.
Once arrived at the desired setting press the SELECT button to view the value the setting has been set to.
To modify this setting press the SELECT button again, the value will now blink.
Press the - or + button to choose the desired value.
Press SELECT to confirm the change, the value will stop blinking, and the change is made final.
Navigate to the next menu item, or press SETUP to return to the setup menu.
To leave the setup menu, press the SETUP button.
Note
Any settings change via the display or the VictronConnect App will override the rotary switch setting. Turning the rotary switch will override settings made with the display or via the VictronConnect App.
All available settings are indicated in below table, in the order they appear when scrolling through the menu, together with a basic description and notes for each setting. For the full description of the solar charger settings refer to the solar charger manual.
Number | Scrolling text | LCD | Desription and notes |
01 | POWER ON OFF | This setting turns the charger in the solar charger ON or OFF. | |
02 | MAXIMUM CHARGER CURRENT | Sets the maximum charge current (A). | |
03 | BATTERY VOLTAGE | Sets the system voltage 12, 24, 36 or 48V. | |
04 | CHARGE ALGORITHM | Sets the charge algorithm. A preset charge algorithm has been selected via the rotary switch. This setting toggles between the preset algorithm or a USER defined algorithm. Only when the USER algorithm has been selected, the charge settings in the remainder of the setup menu can be changed. | |
05 | ABSORPTION VOLTAGE | Sets the absorption voltage (V). This setting can only be changed when the charge algorithm has been set to USER in setting 4. | |
06 | FLOAT VOLTAGE | Sets the float voltage (V). This setting can only be changed when the charge algorithm has been set to USER in setting 4. | |
08 | EQUALIZATION VOLTAGE | Sets the equalization voltage (V). This setting can only be changed when the charge algorithm has been set to USER in setting 4. | |
09 | AUTOMATIC EQUALIZATION | Sets if an automatic equalization should take place and how often this should be. Set to OFF 0 (default) or a number between 1 (every day) and 250 (once every 250 days). CautionDo not equalize charge Gel, AGM, VRLA or lithium batteries. Equalization can cause damage to the battery if the battery is not suitable for an equalization charge. Always check with the battery manufacturer prior to enabling equalization. | |
10 | MANUAL EQUALIZATION | Initiates a manual equalization (START, STOP). Only perform a manual equalisation during absorption or float charge stage, and when there is sufficient sunlight. Press SELECT: the text START will blink, press SELECT again to start equalisation. The manual equalise duration is 1 hour. To terminate the equalisation mode prematurely, enter the setup menu and navigate to setup item 10, press SELECT: the text STOP will blink, press SELECT again to stop equalisation. CautionDo not equalize charge Gel, AGM, VRLA or lithium batteries. Equalization can cause damage to the battery if the battery is not suitable for an equalization charge. Always check with the battery manufacturer prior to enabling equalization. | |
11 | RELAY MODE | Sets the relay function:
12 | RELAY LOW VOLTAGE | Sets the low battery voltage alarm activation level (V) | |
13 | RELAY CLEAR LOW VOLTAGE | Sets the low battery voltage alarm clear level (V). | |
14 | RELAY HIGH VOLTAGE | Sets the high battery voltage alarm activation level (V). | |
15 | RELAY CLEAR HIGH VOLTAGE | Sets the high battery voltage alarm clear level (V). | |
16 | RELAY HIGH PANEL VOLTAGE | Sets the high PV voltage alarm activation level (V). | |
17 | RELAY CLEAR HIGH PANEL VOLTAGE | Sets the high PV voltage alarm clear level (V). | |
18 | RELAY MINIMUM CLOSED TIME | Sets the relay minimum closed time (minutes). | |
20 | TEMPERATURE COMPENSATION | Sets the temperature charge voltage compensation factor (°C/mV or °F/mV). This is the value per cell. A 12V lead acid battery has 4 cells. A setting of 0 disables the temperature compensation. Temperature compensated charging is not required for lithium batteries. This setting can only be changed when the charge algorithm has been set to USER in setting 4. | |
21 | TAIL CURRENT | Sets the tail current (A). | |
23 | MAXIMUM ABSORPTION TIME | Sets maximum absorption time (h). | |
28 | REBULK OFFSET VOLTAGE | Sets the re-bulk offset voltage (V). This voltage is subtracted from setting 6. | |
29 | LOW TEMPERATURE CHARGE CURRENT | Sets the low temperature charge current (A) for when the temperature drops below 5°C or the temperature as set in setting 30 (A). | |
30 | LOW TEMPERATURE LEVEL | Sets low temperature level at which charging has to stop (°C or °F). | |
31 | BMS PRESENT | Sets if BMS is present (Y or N). This setting is automatically set to Y when a compatible BMS is detected. To revert the solar charger to normal operation (without BMS) set manually to N. For example if the charger is moved to another location were a BMS is not needed. CautionDo not set to Y when a BMS is connected to the solar charger's remote on/off terminal. | |
35 | LOAD MODE | Sets the load control mode the relay (setting 11, value 10) or the VE.Direct port (setting 58, value 4) is using to control a load:
* Settings are for 24V systems, for 12V systems devide by 2, for 24V systems multiply by 2. | |
36 | LOAD LOW VOLTAGE | Sets the load low voltage (V). | |
37 | LOAD HIGH VOLTAGE | Sets the load high voltage (V). | |
40 | MAXIMUM EQUALIZATION TIME | Sets the maximum automatic equalization time (h). | |
41 | EQUALIZATION AUTO STOP | Sets if the equalization should stop when the equalization voltage (setting 8) has been reached (Y or N). | |
42 | EQUALIZATION CURRENT PERCENTAGE | Sets the equalization current as a percentage (%) of the maximum charge current setting entered in setting 2. This setting can only be changed when the charge algorithm has been set to USER in setting 4. | |
49 | BACKLIGHT INTENSITY | Sets the display's backlight intensity level (0 or 1). | |
50 | BACKLIGHT ALWAYS ON | Sets when the back light should turn off after the last keypress:
51 | SCROLL SPEED | Sets the scroll speed (1 to 5). | |
57 | RX MODE | Sets the VE.Direct port RX pin mode:
58 | TX MODE | Sets the VE.Direct port TX pin mode:
61 | SOFTWARE VERSION | Displays the firmware version of the solar charger. | |
62 | RESTORE DEFAULTS | Resets all settings to default. Press SELECT: the text “RESET” will blink, press SELECT again to reset to original factory settings. The charger will re-boot. The history data will not be affected. | |
63 | CLEAR HISTORY | Resets all historic data. Press SELECT: the text “CLEAR” will blink, press SELECT again to erase the history data. Note that this takes a few seconds to complete. | |
64 | LOCK SETUP | Locks settings (Y or N). | |
67 | TEMPERATURE UNIT | Sets the temperature unit to °C or °F (CELC or FAHR) |
