It is best practice to save a copy of the settings in case they are lost from the VE.Bus device (eg during a firmware update).
This can be done from the file menu:
There are two options, and both should be done, you can save a re-loadable .VSC file. This file can be opened by VEConfigure.
You can also Export and save a .txt file, which makes the settings human readable in any text editor.
