All settings are sent to the device via the MK3. This action is required to effectuate any changes done in the settings. Until this button is pushed, the settings and changes made will not be on the device.
The user is prompted with a dialog box to determine whether or not to send all settings or only the changed ones.
Note: If using a system with multiple units (eg parallel, split- or 3 phase) when working with VEConfigure, it must be started from within VE.Bus Quick Configure or VE.Bus System Configurator. This will enable a further dialogue option 'send where?', to set where to send the settings (i.e. to which one(s) of the connected devices).
