Blue Smart IP67 Charger | 12V 7 / 13 / 17 / 25A | 24V 5 / 8 / 12A |
Input voltage and frequency range | 180 - 265VAC | 45 - 65Hz | |
Efficiency | 93% / 93% / 95% / 95% | 94% / 96% / 96% |
Standby power consumption | 0.5W | |
Charge voltage - Absorption | Normal: 14.4V High: 14.7V Li-ion: 14.2V | Normal: 28.8V High: 29.4V Li-ion: 28,4V |
Charge voltage - Float | Normal: 13.8V High: 13.8V Li-ion: 13.5V | Normal: 27.6V High: 27.6V Li-ion: 27.0V |
Charge voltage - Storage | Normal: 13.2V High: 13.2V Li-ion: 13.5V | Normal: 26.4V High: 26.4V Li-ion: 27.0V |
Max output current - Normal mode | 7 / 13 / 17 / 25A | 5 / 8 / 12A |
Max output current - Low current mode | 2 / 4 / 6 / 10A | 2 / 3 / 4A |
Max battery capacity (recommended) | 70 / 130 / 170 / 250Ah | 50 / 80 /120Ah |
Min battery capacity - Normal mode | Lead-acid: 23 / 43 / 57 / 83Ah Lithium: 14 / 26 / 34 / 50Ah | Lead-acid: 17 / 27 / 40Ah Lithium: 10 / 16 / 24Ah |
Min battery capacity - Low current mode | Lead acid: 7 / 13 / 20 / 33Ah Lithium: 4 / 8 / 12 / 20Ah | Lead acid: 7 / 10 / 13 Ah Lithium: 4 / 6 / 8 Ah |
Temperature compensation (lead-acid only) | 16mV/°C | 32mV/°C |
Charge algorithm | 6-stage adaptive | |
Power supply mode | Yes | |
Back current drain | 0.7Ah/month (1mA) | |
Protection | Reverse polarity (fuse), output short circuit, over temperature | |
DC fuse - Internal (not replaceable) | n.a. / n.a. / 35A / 30A | n.a. / 25A / 33A |
DC fuse - ATO blade in DC cable | 20A / 20A / 30A / n.a | 20A / 20A / 25A |
Operating temperature | -20 to +60°C (full rated output up to 40°C) | |
Humidity | Up to 100% | |
Start interrupt option (12/25 and 24/12) | Short circuit protected, 0.5A limit, max 1V lower than output voltage | |
Enclosure | ||
Material & Colour | Aluminium (blue RAL 5012) | |
Battery connection | 1.5 meter red and black cable with M8 ring terminals 12/7, 12/13, 24/5 - 12 AWG | 12/17, 12/25, 24/8, 24/12 - 9 AWG | |
AC connection | 1.5m cable with CEE 7/7, BS 1363 or AS/NZS 3112 plug | |
Protection category | IP67 | |
Weight | 12/7, 12/13, 24/5: 1.8kg | 12/17, 12/25, 24/8, 24/12: 2.4kg | |
Dimensions (h x w x d) | 12/7, 12/13, 24/5: 85 x 211 x 60mm 12/17, 12/25, 24/8, 24/12: 99 x 219 x 65mm | |
Standards | ||
Safety | EN 60335-1, EN 60335-2-29 | |
Emission | EN 55014-1, EN 61000-6-3, EN 61000-3-2 | |
Immunity | EN 55014-2, EN 61000-6-1, EN 61000-6-2, EN 61000-3-3 |
