Victron VM-3P75CT Energy Meter Manual
2. Introduction
In this section:
The Victron VM-3P75CT energy meter is a standard device to measure the power and energy of single-, split- and three-phase applications and calculates each phase's power values and broadcasts this over VE.Can or Ethernet with a high rate.
It has built-in Ethernet and VE.Can ports for connecting to a GX device and the split-core current transformers enable easy and quick installation without modifying existing wiring.
The energy meter works out of the box (the firmware may need to be updated; details can be found in the Firmware Updates chapter) as a grid meter for systems with a MultiPlus and Quattro. Configuration (via VictronConnect) is only required for changing the role and manual IP configuration rather than the default DHCP.
Its data is displayed on a GX device such as the Cerbo GX or Ekrano GX , as well as in VictronConnect and our VRM Portal.
2.1. Features
  • Capable of measuring up to 80Arms (Amps root mean square) per phase (but rated at 75A)
  • Modbus/UDP communication over Ethernet
  • Split-core current transformers for easy installation without modifying the existing wiring
  • Support for split-phase configuration
  • Configurable total energy registration method (vector, arithmetic, absolute)
  • Reporting of line-to-neutral, line-to-line and protective earth voltages as well as neutral and line currents
  • Status LED can be configured as LED pulse counter for quick diagnostics at a glance
The VM-3P75CT can be configured for four different roles in a GX device, such as the Cerbo GX or the Ekrano GX:
  1. As a Grid meter and used as control input for an Energy Storage System (ESS)
  2. To measure the output of a PV Inverter
  3. To measure the output of an AC Genset
  4. As an AC meter to measure a dedicated AC load circuit
It offers two options for connecting to a GX device:
  1. A wired ethernet connection to a local network via its built-in Ethernet port so the GX device can reach it.
  2. A wired VE.Can connection via the onboard VE.Can port directly to the GX device.
2.2. What's in the box?
Victron VM-3P75CT with 3 input terminal blocks
VM-3P75CT.svg
3x Split-core current transformer, wired ready for connection
Wire length: 640mm (25.3in)
Split-core_Current_Transformers.svg
VE.Can terminators (2 pcs)
2x_VE_Can_Terminator.svg
