Quattro-II 230V | 24/5000/120-50 | 48/5000/70-50 | ||
PowerControl / PowerAssist | Yes | |||
AC input | Input voltage range: 187 - 265VAC Input frequency: 45 - 65Hz | |||
Maximum feed through current | 50 A | |||
INVERTER | ||||
Input voltage range | 19 – 33V | 38 – 66V | ||
Output in inverter mode (1) | Output voltage: 230VAC ± 2% Frequency: 50Hz ± 0.1% | |||
Cont. output power at 25°C / 77°F (3) | 5000VA | |||
Cont. output power at 25°C / 77°F | 4000W | |||
Cont. output power at 40°C / 104°F | 3700W | |||
Cont. output power at 65°C / 150°F | 3000W | |||
Maximum feed-in power | 5000VA | |||
Peak power | 9000W | |||
Maximum efficiency | 96% | |||
Zero-load power | 18W | |||
Zero-load power in AES mode | 12W | |||
Zero-load power in Search mode | 2W | |||
CHARGER | ||||
AC input | Input voltage range: 187 - 265VAC Input frequency: 45 - 65Hz Power factor: 1 | |||
Charge voltage 'absorption' | 28.8V | 57.6V | ||
Charge voltage 'float' | 27.6V | 55.2V | ||
Storage mode | 26.4V | 52.8V | ||
Charge current house battery (4) | 120A | 70A | ||
GENERAL | ||||
Auxiliary output (5) | Yes (32A) | |||
Programmable relay (6) | Yes | |||
Protection (2) | a - g | |||
VE.Bus communication port | For parallel and three-phase operation, remote monitoring and system integration | |||
General purpose com. port | Yes, 2x | |||
Common Characteristics | Operating temp.: -40 to +65°C (-40 – 150°F) (fan-assisted cooling) Humidity (non-condensing): max 95% Maximum Altitude 2000m | |||
ENCLOSURE | ||||
Material & colour | Steel, blue RAL 5012 Protection category: IP21 Pollution degree 2, OVC3 | |||
Battery connections | M8 bolts | |||
230 VAC connections | Screw terminals 13 mm² (6 AWG) | |||
Weight | 31 kg | 29 kg | ||
Dimensions (hxwxd) | 607 x 329 x 149 mm | 565 x 320 x 148 mm | ||
STANDARDS | ||||
Safety | EN 60335-1, EN 60335-2-29, IEC62109-1, IEC62109-2 | |||
Emission / Immunity | EN 55014-1, EN 55014-2, EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, EN 61000-6-2, EN 61000-6-3 | |||
Uninterruptible power supply | Please consult the certificates on our website. | |||
Anti-islanding | Please consult the certificates on our website. | |||
