# | Description |
1 | AC source, grid or generator |
2 | Circuit breaker |
3 | MultiPlus-II Inverter/charger |
4 | Remote on/off switch |
5 | VE.Bus BMS V2 |
6 | Cerbo GX |
7 | AC-DC power supply, providing backup power to the Cerbo GX should the battery be too far discharged |
8 | Pre-alarm warning circuit, giving an advanced warning in case of an imminent system shutdown due to a too far discharged battery |
9 | Lithium Battery Smart or battery consisting of multiple batteries creating a 12V, 24V or 48V battery bank |
# | Description |
4 | Solar charger |
5 | VE.Direct non-inverting remote on/off cable connects between the solar charger VE.Direct port and the BMS Charge disconnect terminal |
6 | VE.Bus BMS V2 |
7 | Lithium Battery Smart or battery consisting of multiple batteries creating a 12V, 24V or 48V battery bank. |
8 | BatteryProtect |
9 | DC loads |
10 | SmartShunt |
# | Description |
1 | MultiPlus-II Inverter/charger |
2 | VE.Bus BMS V2 |
3 | Lithium Battery Smart or battery consisting of multiple batteries creating a 12V, 24V or 48V battery bank |
# | Description |
3 | Orion DC-DC charger, the remote H terminal is connected to the Charge disconnect terminal on the VE.Bus V2 BMS |
4 | VE.Bus BMS V2 |
5 | MultiPlus-II Inverter/charger |
6 | Starter monitor and alternator |
7 | 12V starter battery |
8 | Lithium Battery Smart or battery consisting of multiple batteries creating a 12V or 24V battery bank |
9 | SmartShunt |
# | Description |
1 | Digital Multi Control |
2 | MultiPlus-II Inverter/charger installed and configured as a 3-phase system |
3 | VE.Bus BMS V2 |
4 | Lithium Battery Smart or battery consisting of multiple batteries creating a 12V, 24V or 48V battery bank |
