1. General
Product, system and fault information | |
Date | .... |
Model | .... |
Part number | .... |
Serial number | .... |
Date of installation (if known) | .... |
Date of failure (if known) | .... |
VRM site name or ID (if applicable) | .... |
Battery type, brand name and overall capacity (if known) | .... |
Solar array power rating (W) | .... |
Solar array maximum open-circuit voltage (V) | .... |
2. Initial check
Initial check | |||
Does the unit have mechanical damage to its housing? |
Does the unit have burn marks or melting marks on its housing? |
Does the unit have mechanical or burn damage to its electrical connectors? |
For the 15A model only: Is there sand coming out of the unit? Background information: Sand is used as a cooling agent. If the unit has sustained mechanical damage, like being dropped from a height onto a hard floor, the unit might get damaged so that sand is coming out of the unit. Mechanical damage is not covered by warranty. |
For 10A, 15A and 20A models only:
Background information: If the replacement fuse blows, the solar charger has a short circuit; this is almost always an indication that the solar charger has been connected to reverse battery polarity. Reverse battery polarity is not covered under warranty. |
For models with a remote link only:
3. PV short relay check
PV short relay check | |||
Is the unit a 250/100 TR VE.Can model? |
Does the unit have a serial number HQ2150 and above? |
Power the solar charger with a bench power supply set to 12V and a current limit of 0.4A connected to the battery terminals. Does it turn on? |
Background information: This solar charger features a safety latching relay that, when activated, causes a short circuit at the PV terminals. The reset procedure seeks to unlatch the relay, resolving the short-circuit. However, the reset may not always succeed. For additional information, see https://www.victronenergy.com/live/mppt_pv_short_relay_reset. |
4. FET check and first power up
FET and power up check | |||
Background information: If the LEDs did not illuminate at all (not even briefly), this usually signals that the internal, non-replaceable fuse has blown due to a reverse battery polarity connection. Note that reverse battery polarity is not covered under the warranty. |
Background information: A short circuit on the PV terminals is nearly always an indication that the solar charger has been connected to a too high PV voltage or there has been a too high short circuit current (can occur when there is PV reverse polarity and PV array is too big). Both situations are not covered under warranty. The maximum PV open circuit voltage and maximum PV short circuit current are indicated in the product manual and datasheet. |
Are any LED(s) on or blinking? |
5. Bluetooth
Bluetooth check | |
Is the unit a "Smart" product, i.e., does it have built-in Bluetooth? |
Is Bluetooth active, i.e., do you see the unit listed in the device list of the VictronConnect app? |
If Bluetooth is not active, it is unlikely to be a faulty Bluetooth module. More likely, Bluetooth has been turned off in the VictronConnect settings. To re-activate Bluetooth:
Is Bluetooth active now? |
If Bluetooth is still not active, rule out the following:
6. Firmware and settings
Update the firmware and reset the settings to default | |
Connect via an interface (or Bluetooth) to the VictronConnect app and navigate to the unit. Is this possible? |
Check if the firmware is up to date. If the firmware is not up to date, update the firmware to the most recent version using the VictronConnect app:
NoticeNote that when connected via Bluetooth, both the solar charger and the BLE module needs to be up to date. If connecting via VE.Direct, only the solar charger needs to be up to date. |
Save the unit's settings. File the settings under its serial number and keep the file on record for future reference. To save the settings:
Reset all settings to default:
Does the VictronConnect app display any active error codes? If so, try to resolve the errors by consulting the product manual. Did it get resolved? |
If there is an active error, write down the error number(s) and name(s). Use this form's "Remarks" section if more space is needed. | Error number: .... Error name: .... |
Check the history. Were there any historical errors? If so, write them down. Save a copy of the history file for your reference. |
Check the history tab. What was the highest PV voltage recorded? Compare this to the rated maximum PV voltage of the solar charger. Has the PV voltage been higher than the rated maximum voltage? |
Check the trents tab. Does it contain data? |
7. Functionality
Solar charger functionality check | |||
Prepare the solar charger for the functionality test:
Measure the voltage on the solar charger PV terminals. Compare this to the solar voltage as indicated in the VictronConnect app. Are they both the same? A small deviation is allowed due to measurement inaccuracies. |
Measure the voltage on the solar charger battery terminals. Compare this to the battery voltage as indicated in the VictronConnect app. Are they both the same? A small deviation is allowed due to measurement inaccuracies. |
Is the battery being charged? Check if the solar charger is progressing through the bulk, absorption and float charge stages. Is this the case? |
Force the solar charger to provide more charge current by connecting it to an empty battery or by switching on a large DC load connected to the same battery. Is the unit able to provide its full current rating? |
Measure the charge current with a DC current clamp. Is the charge current the same as indicated in the VictronConnect app? A small deviation is allowed due to measurement inaccuracies. |
While the solar charger is providing the full current, measure the battery voltage. Compare this to the voltage as indicated in the VictronConnect app. Do the voltages deviate less than 3% from each other? |
8. Remarks
Provide additional fault information or add issues not already covered in earlier questions |
9. RMA lodgement
For your information purposes, provide details after lodging the RMA | |
RMA type: |
RMA lodgement date | .... |
Victron Energy RMA number | .... |
Your reference number | .... |
