Pre-RMA Bench Test Instructions
10. Pre-RMA test form - Orion-Tr DC-DC converter
1. General
Product, system and fault information
Date
Model
Part number
Serial number
Date of installation (if known)
Date of failure (if known)
Battery type, brand name and overall capacity (if known)
2. Initial check
Table 1.
Initial check
Does the unit have mechanical damage to its housing?
  • Yes, no warranty.
  • No.
Does the unit have burn marks or melting marks on its housing, or does it smell burned?
Notice
The potting used in the Orion may emit a slight odour, but this is not a cause for concern.
  • Yes.
  • No.
Does the unit have mechanical or burn damage to its electrical connectors?
  • Yes, no warranty.
  • No.
3. First power up
Power the unit up and check
For models with a remote link only:
Check if the remote link is in place; if not, place the link.
Note: To find the location of the remote link, refer to the product manual.
  • The link was placed.
  • The link was not placed and has now been placed.
Connect the input terminals to a current limited 12, 24 or 48V power supply (depending on the model) or a battery with a DC fuse. Is there a DC short circuit?
Notice
Instead of a power supply, you can also use a multimeter to check for a short circuit.
Background information: A DC short circuit nearly always indicates that the DC-DC converter has been connected to reverse battery polarity. Reverse battery polarity is not covered under warranty.
  • No.
  • Yes, and there was reverse battery polarity; no warranty.
  • Yes, and there was no reverse battery polarity; lodge a warranty claim.
For DC-DC converters with an external fuse:
Remove the fuse and check the fuse for continuity. If the fuse is broken, replace the fuse. What is the outcome?
Background information: If the replacement fuse blows, the DC-DC converter has a short circuit; this is nearly always an indication that the DC-DC converter has been connected to reverse battery polarity. Reverse battery polarity is not covered under warranty.
  • The fuse is not broken.
  • The replacement fuse blew, and there was reverse battery polarity; no warranty.
  • The replacement fuse blew, and there was no reverse polarity; lodge a warranty claim.
  • The fuse was broken and has been replaced.
4. Bluetooth
Bluetooth check
Is the unit a "Smart" product, i.e., does it have built-in Bluetooth?
  • Yes.
  • No, go to step 6.
Is Bluetooth active, i.e., do you see the unit listed in the device list of the VictronConnect app?
  • Yes, go to step 5.
  • No.
If Bluetooth is not active, it is unlikely to be a faulty Bluetooth module. More likely, Bluetooth has been turned off in the VictronConnect settings.
To re-activate Bluetooth:
  • In the unit's VictronConnect app "product info" page, three options are available for Bluetooth behaviour:
    - Bluetooth enabled.
    - Bluetooth enabled for 30 seconds.
    - Bluetooth disabled.
  • If the "Bluetooth enabled for 30 seconds" option was chosen, you can re-activate Bluetooth by unpowering and repowering the unit, then navigating to the unit's product settings to re-enable Bluetooth.
  • However, if the "Bluetooth disabled" option was chosen, it is not possible to re-activate Bluetooth.
Is Bluetooth active now?
  • No.
If Bluetooth is still not active, rule out the following:
  • Are there problems with your phone or tablet?
  • Are you within Bluetooth range?
  • Just one phone or tablet can connect via Bluetooth at once. If another is connected, the unit will be listed but greyed out in VictronConnect app.
  • Consult the product manual and the VictronConnect manual to try to resolve the Bluetooth issue.
  • Yes.
  • No, lodge a warranty claim.
5. Firmware and settings
Update the firmware and reset the settings to default
Use the VictronConnect app and select the unit in the device list. Is this possible?
In case the PIN code is unknown, reset the PIN code, using the PUK code. For information on how to do this, see the VictronConnect manual.
  • Yes.
  • No, not possible; lodge a warranty claim.
Check if the firmware is up to date. If the firmware is not up to date, update the firmware to the most recent version using the VictronConnect app:
  • Go to the VictronConnect settings page.
  • On the settings page, click on the "3 dots" symbol in the top right-hand corner.
  • Select "Product info".
  • On the product info page, check and/or update the firmware.
  • Yes, the firmware has been updated.
  • Yes, the firmware was already up to date.
  • No, not possible to update the firmware.
Save the unit's settings. File the settings under its serial number and keep the file on record for future reference. To save the settings:
  • On the settings page, click on the "disk" symbol at the top.
  • Yes, the settings file has been saved.
  • No, not possible to save the settings.
Reset all settings to default:
  • On the settings page, click on the "3 dots" symbol in the top right-hand corner of the page and select "Reset to defaults".
  • Yes, the settings are set to default.
  • No, not possible to set the settings to default.
Does the VictronConnect app display any error codes? If so, try to resolve the errors by consulting the product manual.
Did it get resolved?
  • No errors, go to 6.
  • There were errors, but they were resolved.
  • There were errors, but they were not resolved.
Write down the error number and name.
Error number: ....
Error name: ....
6. Functionality
DC-DC converter functional check
Measure the voltage on the output terminals. Do you measure a voltage higher than 10, 20 or 40V (depending on the model)?
Notice
When the "Engine shutdown detection" feature is enabled, the input voltage must be at least 14, 28, or 56V for the output to be enabled.
  • Yes.
For models with a voltage adjustment screw only:
Measure the voltage on the output terminals. Turn the screw. Is the output voltage decreasing when turning to the left and is it increasing when turning to the right?
  • Yes.
For Smart models only:
Measure the voltage on the input terminals. Compare this to the input voltage as indicated in the VictronConnect app. Are they both the same (a deviation of up to 1% is allowed)?
  • Yes.
Measure the voltage on the output terminals. Compare this to the output voltage as indicated in the VictronConnect app. Are they both the same (a deviation of up to 1% is allowed)?
  • Yes.
Connect a DC load to the output of the DC-DC converter. Can the DC-DC converter deliver its maximum rated power to the DC load?
  • Yes.
Connect an empty battery to the output terminals. Does the DC-DC converter charge the battery?
Notice
For battery charging to occur, the battery voltage must be lower than the output voltage of the DC-DC converter. Charging happens when current flows from the DC-DC converter to the battery. You can verify this by using a DC current clamp. Please note that the charge voltage may take some time to rise after power-up.
  • Yes.
7. Remarks
Provide additional fault information or add issues not already covered in earlier questions
8. RMA lodgement
For your information purposes, provide details after lodging the RMA
RMA type:
  • Warranty claim.
  • Non-warranty repair or replacement request.
RMA lodgement date
Victron Energy RMA number
Your reference number
