Pre-RMA Bench Test Instructions
8. Pre-RMA test form - BMV battery monitors
1. General
Product, system and fault information
Date
Model
Part number
Serial number
Date of installation (if known)
Date of failure (if known)
Battery type, brand name and overall capacity (if known)
2. Initial check
Initial check
Does the shunt have mechanical, water or corrosion damage?
  • Yes, no warranty; replace the shunt.
  • No.
Does the shunt have damage to its electrical connectors?
  • No.
Does the shunt board have mechanical, water or corrosion damage?
  • Yes, no warranty; replace the shunt board.
  • No.
Does the shunt board have damage to its electrical connectors?
  • No.
Is the shunt board securely fastened to the shunt?
  • Yes.
  • No, tighten both screws.
Does the head unit have mechanical, water or corrosion damage?
  • Yes, no warranty; replace the head unit.
  • No.
Does the head unit have damage to any of its electrical connectors?
  • No.
Does the head unit have burn marks or melting marks on its housing, or smell burned?
  • Yes.
  • No.
Remove the fuse from the red power cable and test the fuse for continuity using a digital multimeter. In the case of a BMV 702 or 712, repeat this test for the fuse in the other cable.
  • Yes, no warranty; replace the fuse.
  • No.
Test the red cable(s) for continuity using a multimeter. And inspect the cable(s) for damage. Is there an issue with the cable(s)?
  • Yes, no warranty; replace the cable(s).
  • No.
Test the six strands in the RJ12 data cable for continuity using a cable tester and inspect the cable terminals for damage. Is there an issue with the RJ12 Cable?
  • Yes, no warranty; replace the RJ12 cable.
  • No.
3. First power up
Power the unit up and check
Connect the battery monitor to a 12V power supply or a 12V battery:
  • Connect the negative to the “battery” side of the shunt.
  • Connect the positive to the B1 connector on the shunt.
  • Connect the BMV head unit via an RJ12 cable to the shunt.
Does the battery monitor power up?
  • Yes, go to step 4.
  • No.
Is there a DC short circuit? And if so, determine by process of elimination if the problem is caused by the head unit or the shunt board?
  • Yes, short circuit in the head unit; lodge a warranty claim.
  • Yes, short circuit in the shunt board; lodge a warranty claim.
  • No.
By process of elimination, determine if the reason the battery monitor is not powering up is caused by the head unit or by the shunt board?
  • The head unit causes the problem; lodge a warranty claim.
  • The shunt board causes the problem; lodge a warranty claim.
4. Bluetooth
Bluetooth check
Is the unit a "Smart" product, i.e., does it have built-in Bluetooth?
  • Yes.
  • No, go to step 5.
Is Bluetooth active, i.e., do you see the unit listed in the device list of the VictronConnect app?
  • Yes, go to step 5.
  • No.
If Bluetooth is not active, it is unlikely to be a faulty Bluetooth module. More likely, Bluetooth has been turned off in the VictronConnect settings.
To re-activate Bluetooth, consult the product manual.
Is Bluetooth active now?
  • No.
If Bluetooth is still not active, rule out the following:
  • Are there problems with your phone or tablet?
  • Are you within Bluetooth range?
  • Just one phone or tablet can connect via Bluetooth at once. If another is connected, the unit will be listed but greyed out in VictronConnect app.
  • Consult the product manual and the VictronConnect manual to try to resolve the Bluetooth issue.
  • Yes.
  • No, lodge a warranty claim.
5. Firmware and settings
Update the firmware and reset the settings to default
Connect via an interface (or Bluetooth) to the VictronConnect app and navigate to the unit. Is this possible?
  • Yes.
  • No, not possible; lodge a warranty claim.
Check if the firmware is up to date. If the firmware is not up to date, update the firmware to the most recent version using the VictronConnect app:
  • Go to the VictronConnect settings page.
  • On the settings page, click on the "3 dots" symbol in the top right-hand corner.
  • Select "Product info".
  • On the product info page, check and/or update the firmware.
  • Yes, the firmware has been updated.
  • Yes, the firmware was already up to date.
  • No, not possible to update the firmware.
Save the unit's settings. File the settings under its serial number and keep the file on record for future reference. To save the settings:
  • On the settings page, click on the "disk" symbol at the top.
  • Yes, the settings file has been saved.
  • No, not possible to save the settings.
Reset all settings to default:
  • On the settings page, click on the "3 dots" symbol in the top right-hand corner of the page and select "Reset to defaults".
  • Yes, the settings are set to default.
  • No, not possible to set the settings to default.
Does the VictronConnect app display any error codes? If so, try to resolve the errors by consulting the product manual.
Did it get resolved?
  • No errors, go to 6.
  • There were errors, but they were resolved.
  • There were errors, but they were not resolved.
Write down the error number and name.
Error number: ....
Error name: ....
6. Functionality
Battery monitor functionality check
Measure the battery DC voltage. Compare this to the voltage indicated on the BMV head unit display or the VictronConnect app. Are they both the same (a deviation of up to 1% is allowed)?
  • Yes.
  • No, lodge warranty claim.
Connect a DC load or charger of approximately 50A to the load side of the BMV shunt. Measure the charge current with a DC current clamp. Is the current the same as is indicated in the VictronConnect app (a deviation of up to 1% is allowed)?
  • Yes.
Leave the DC charger or load connected for some time, is the "state of charge" (SoC) reading slowly changing?
  • Yes.
Are all display segments functional and legible?
  • Yes.
Is the display backlight functional? The backlight should turn on as soon as a button is pressed.
Note: The display backlight can also have been turned off in the settings (setting #50). See the product manual for more information on this.
  • Yes.
7. Remarks
Provide additional fault information or add issues not already covered in earlier questions
8. RMA lodgement
For your information purposes, provide details after lodging the RMA
RMA type:
  • Warranty claim.
  • Non-warranty repair or replacement request.
RMA lodgement date
Victron Energy RMA number
Your reference number
